driven clutch what to get
  • Thread starter Thread starter woodies
  • Start date Start date
W
woodies
Guest
i want a better back clutch easier to tune on my 06 f-cat jack shaft style not diamond drive any suggestions?
Honestly your stock AC Roller is one of the easiest to tune and make work correctly. It's a good clutch and was swapped onto many other brands for that reason. The Team is also a good option but helixes are expensive and it takes a little different approach to tuning. It all comes down to how much you want to spend but I'll tell you right now your stock AC roller is the cheapest clutch to play with tuning.
not as easy as diamond drive was why i wondered may need to see about different helix or spring combo then
What parts you change depends on what you want to change about the way it shifts. The cat reverse cam secondary is by far the easiest and cheapest to tune.
Hcx secondary is made by super torquer inc. www.supertorquer.com I've tried many other back clutches including arctics back roller and the team clutchs and the hcx is way superior although a little pricey
