You are right, its a lame a$$ design, you never see $hit like this in 150 hp sleds which never have these problems. Another bigger IMO issue is the diameter of the roll pin is smaller than the keyway slot which allows the pin to move back and forth ever so slightly, then over time it wears the washers and loosens. It's not like I don't do maintenance seems like that's all I do on this POS. I've added a second roll pin to the big a$$ washers but I'm not expecting it will help very much, its more of a backup to help the locking plate not split as quite as fast. I've also added a thin flat washer under the bolt head which may become sacrificial if there is any movement.
The only reason I'm even keeping this kit is so I can set up a second bike for occasional use by family members but I'm really of a mind that its not worth the effort. Here in Canada there are really only 2 kit options if you want a dealer network and any support at all. TS parts and service is a complete joke where Yeti is awesome and as a bonus its local. As it stands now the Yeti kit is getting close but I'm glad I didn't spring for a 2016 because they have made significant improvements for 17 between the shocks and the track etc. IMO its unreasonable to expect customers to throw another $2k at a one year old kit to make it run with the latest model, for example, they had the Maxtrack which was supposed to be THE track for last season then replaced it now they are blowing them out which will kill the used track market for guys who choose to upgrade to the 2. Until things stabilize a bit in this sport I'm in a holding pattern but the 17 Yeti is looking better and better everyday, I guess time will tell.
M5
