Less yanking bars and more leaning of the ski!
Crust on a Yeti Ski... try less yanking of the bars and more leaning of the bike / ski!
Similar to skiing in crust and crud on skis.. the ones you put on your feet!... keep the tips pointed into the crust and increase the angle of lean to turn. This will push through the crust in line with the ski, minimize side to side pull... and keep your skis connected to the boots and knees out of surgery. Also works on the bike...
The Yeti ski has a natural turn angle when you lean it... same as those skiing skis!it has side cuts with a wider tip and tail.. narrower middle... so keep ski pointed straight and LEAN. It will turn through its shape in a natural arc.
Lean in an exaggerated motocross style.. elbows up. Sit on the side of the seat like your railing ruts in a berm on the pro circuit!!
Really bad crust in a straight line... put a lean the bike so you are always turning slightly from one side of the trail to the other. The ski is more stable when not in a neutral position... this is true of ANY ski in crust.
Other skis are more parallel... wash out easier if pushed hard... but are more forgiving for the average rider.
Meh!!! But yeah if Im feeling lazy and just want to cruise I temporarily put an old (Not NEW) timbersled ski on front and cruise!...
