Just got the 2010 updates installed last week. FINALLY. Ran better than it ever has after about 50 miles were put on it. Ran blue the first 50 miles. Then Gold plus 100 miles since. New fuel filter, new exhaust valve springs, New SLP pipe/can.
Clutching is also MUCH better. Doesn't bog down rpms as bad in the deep stuff on J-hooks or steep climbs like the 09 motor. In the 09 motor I was using the stock helix with 10-58 weights. Now using 60/40.36 helix with 10-62 weights (and a new belt). Riding at 9-11K ft. Was very impressed that it's actually pulling 10-62's now since I've never ran that heavy of a weight where I ride before on either sled. 7900-8000rpms on climbs in the deep and 8200 rpms on the flats. In the 09 motor it would bog to 7500-7700 rpms in the deep steeps and run 8100-8200 on flats.
Only thing I noticed while riding. Once I got up to elevation the sled would only idle at 1000 rpms. Did not like that. Thinking this is why...
Went to unload yesterday. Started up great the second pull. I turned it off after unloading and went to start it again. Nothing. No spark. Plugs are soaking wet. So, did my voltage regulator just crap out or what?
