So I just installed a fix kit on a 10 dragon 800 1500 miles sled ran perfect so I decided to update the top end as a precaution everything looked great inside checked everything out all was great installed the kit fired right up ran smooth sounded great took it out and it seized 4 times in a 1/4 mile both pistons toast and cylinder ruined, they say no fuel controller required but this thing was apparently lean after install of the kit nothing was changed other than the pistons and spacer plate and both gaskets no leaks water full and circulating heat soaked it three times temps never got over 125 (wouldn't run long enough to get hot) anyone else have this happen?
