Dpm help
Remove dpm tube
plug the 1 large tube port between carbs, 01 might have one on each carb that needs plugged. the newer sleds had one.
there is a smaller port on top of each carb. put hoses on and let dangle down
start with jetting you have and adjust from there.
Ok, So the bigger tubes that are attatched to the float bowl need tobe plugged but the small tubes on top need to be left open! Good deal, I Left all of them open and the sled had no power this weekend,
