We have developed an affordable controller to drive 1-4 extra injectors with reference to boost & RPM which is all plug n play. The controller will fire the injectors in "sequential" order. Meaning the auxiliary injector will fire at the same time as the stock injector. So if the mag stock injector triggers then the auxiliary injector will fire on the mag side simultaneously. This helps make a smooth transition into boost. Almost all other controllers out there are firing the Auxiliary injectors in batch. The controller will not compromise stock fueling and only tap on for the injector signals.
There will be several modes to adjust:
Mode 1 - Fuel turn on point with reference to boost. (ex: 0.5 - 4 psi**)
Mode 2 - Amount of fuel to be added at turn on point. (ex: 0 - 20%*)
Mode 3 - Upper boost threshold. (ex: 8 - 15 psi**) on board sensor
(ex: 8 - 28 psi**) on external 3 bar sensor
Mode 4 - Amount of fuel to be added at Upper boost threshold. (ex: 40 - 100%*)
Other modes are available for RPM based fueling if needed.
*All percentages are based off stock vehicles Max Pulse Width.
**All pressure are based on sea level atmospheric pressure.
Available for any fuel injected applications, a variety of connectors are available.
$250.00 (1 & 2 Injectors On Board Pressure)
$300.00 (1 & 2 Injectors External Pressure)
$300.00 (3 & 4 Injectors On Board Pressure)
$350.00 (3 & 4 Injectors External Pressure)
Any questions please give me a call.
Chris Shover
Dobeck Performance
877-764-3337
Chris Shover
Dobeck Performance
877-764-3337
