Double Down Pipe
Im new here, but Ive been told that there is an advantage with the DD pipe do to opening up at the waist gate, True or false.
True,allows wastegate to fully open and dump into its own pipe, You may want to have your wastegate ported on your turbo.Does your current downpipe have a flex joint?
I did my own double downpipe which I got ceramic coated.
It exits thru sidepanel instead of tunnel.
Since I run very high boost numbers I will make another one with 3" pipe along with a wastegate devorced pipe as my current one... juste bigger.
Pipe has O2 bung on it too.
I can sell it is someone want it... was used 4 times only.
Cost me a over 600$ to make... so make an reasonable offer it you want it... its one of a kind.
