The marks on the new shaft are wrong. Before pressing off drivers, scribe lines at the edge of the drivers. Then you can compare with the new shaft and adjust accordingly.
![122fbb58f1815ba05a75c02025ac6d85.jpg](http://tapatalk.imageshack.com/v2/14/11/13/122fbb58f1815ba05a75c02025ac6d85.jpg)
At this point, I am glad I procrastinated. Would you guys be kind enough to list the proper measurements? Perhaps the measurements from each end of the shaft to the outer (and maybe inner) edges of the drivers?
It shouldn't matter but, I am assuming that old style (2.52") drivers will be in the same position on the shaft as the new (2.86") drivers? Right?
Mine is just about done. I just scribed the position of the drivers on the old drive shaft before removing the drivers and laid the old driveshaft against the new driveshaft and transcribed the marks over to the new shaft.
The most trouble I had was with pulling the sprockets off the counter shaft and I upgraded to the new flex-shaft front suspension arm. Of course it came with no instructions. After putting it together and pulling it apart several time, I hope I have it right.
The hardest part for me is getting the new front flexible suspension arm to line up with the existing holes in the tunnel sides. I am starting to wonder if maybe it's slightly longer...
Anyone else notice any side to side flex in the side panels? I installed the new bearing kit and ran it elevated in the shop to check it out before I hit the snow. Had LOTS of side to side flex and the chain went from way loose to to tight every rev. Measured (with dial indicator) shaft run out of .012" at the drive side end and side plate flex over .040"...turned out that the new shaft for the double bearings was bent...badly bent as supplied by TS. TS swapped it out for me no questions asked and I got the feeling they know this issue. IF I hadn't noticed it in the shop the bearings would have been ruined pretty quick. Glad I saw it before I had to deal with it out in the hills! I recommend actually checking yours to see what they supplied you!
In an effort to reduce the inaccuracy...voila!
