OIL, OIL, OIL!!! our shop Pro uses very little as set from the factory-turn up the pump and always run extra in the tank! We did the same on the IQ's-no oil related failures!
so for a short block they are charging you over $2000 in labor? we barely get that to put a deisel in a ford superduty. this is why I do my own work. the dealer is slow, they are mostly not knowledgable. (at least around here) there are some good dealers but few and far between. if it takes a dealer that long to do a motor run. I would rather have someone who can do it in 5 hrs then someone who takes 20hrs. I can pull a subaru motor, replace the head gaskets and have running in under 5hrs, I have done a bunch of them. so a guy who does it fast does not mean he's not doing it right. he know what hes doing and is what I would want
check your oil usage, if you are not going through much oil it will happen again!!! I call bs on the a shortblock costing $4300. went on babbits priced out pistons, crank, and cases. no seals though and it is $1782. Add cylinders and head to it and its $2773. you will need seals and gaskets so throw in another $100 on top of it. they are full of crap and are a rip off if they are charging that much. I would say 5 hrs at the most to R&R the motor and rebuild it.
The motor in my Pro let go with 800 miles on the OD, It was replaced with a new short block in 14 days of bringing the sled back to the dealer which was great! I asked the dealer to look up and see what a new motor would cost if your warranty was denied, they came up with $4,300 for a short blockWTF is Polaris thinking? It's a 2 cylinder 2 stroke, not a 8 cylinder diesel.
I know most engines are rebuild able, but I've seen a few Pro motors when the block was split where the crank and rod had punched through the block right next to the water pump.
What was the cause of the failure? What was your oil to gas ratio? What kind of oil do you use? Mods? Clutching/elevation? Thanks just curious. If it was preventable I would like to prevent it on mine as where i ride there is no towing out![]()
I want to know where I can get a new diesel motor for only $4,300.
I talked to my dealer today about turning up the oil pump, The head mechanic and parts department manager both told me that Polaris's fuel map in the stock ECU is built around the Stock oil injection ratio? They both felt that turning the pump up would cause the motor to run to rich, they recommended running 5-6oz in the tank.
As far as I'm concerned, my motor is still warrantied for 3 more years! I'll just going to keep doing what I've been doing and ride the thing.
Looks like Poo hasn't gotten away from the motor woes yet.
I'd def. run a light pre-mix if I were you. Can't hurt
i'll take the 20hr guy, the 5hr guy sounds like he's used to doing nothing but flat rate work, when you own your own business you learn this is not the way to do things. if you brag about how fast you do your work i wouldn't be interested in letting you touch anything of mine. i'm more interested in hearing from my mechanic about the quality of work he did, how he fixed that loose hose while he was there cause it looked like it might cause a leak later on. or how he spent more than half of that 6 hours you quoted just cleaning the thing spotless and making sure there would be no unexpected problems come up. quality takes time, after running my own auto repair business for over 20 years i've seen way too many mechanics who were sooooo fast they could r&r anything faster than me, then to have thier work return in 2 days with this loose and that left undone... quality, i'd say find a mechanic who cares more about the end product than how fast he can get the job done!!! in the long run you'll come out money ahead. i have a sign in my shop that says "were not the cheapest at anything"... gets rid of those customers right away that are looking for nothing but cheap, and those are the kind of customers i'm not interested in having.
If the injectors are in the transfers, and are timed to squirt on the updraft, how does the extra oil put in the tank get on the rod and crank bearings?
E X A C T L Y! I don't give two sh#ts what my oil ratio is. Polaris set it like that so I'm leaving it and riding it. 1,200 miles so far so good. Hopefully if it lets go, I'll have about 3 or 4k miles on it and I can have a nice fresh motor for my $50 deductible.
