G
Gone Sleddin
2012 silber pro
8-10000 ft
5-7 lbs
100ll
Issue 1
Sled has a stumble at around 5000 rpm. Runs clean below that but sticks there coming through the rpm range, once above that it runs well. The mode on the box goes from 2 green lights at slow speed to 3 green lights as i add throttle. This is where the stumble occurs. As I add more throttle it will jump to 3 yellow lights and clears up from there on. Tre problem seemed to get slightly worse throughout the trip.
Issue 2
Once the sled is warm, it will idle at the correct afr for a time and the slowly the afr will begin to climb until it starts to sputter and I get an E9 on the guage. I had tried to clear up issue 1 by lowering my green but that magnified issue 2.
Issue 3
3 or 4 times in the last 2 days we were riding some logging trails that were pretty whooped out. In and out of the throttle at low speeds. When I would try to get into the throttle I would get a bog that would about throw me over bars and would not come out of it unless I chopped the throttle a few times. When this happened the afr would read way lean. The sled would not run well or even idle unless I could find a stretch to do a couple wide open pulls for a ways.
I emailed back and forth with Justin a few times on the issue and he thought it could be a TPS issue. Sound right to everyone else? Anything else I should look for?
Besides these issues I was happy with the way the sled ran and impressed with the power it had at the lower boost numbers. If I can get this stuff straightened out she will be one fine machine
8-10000 ft
5-7 lbs
100ll
Issue 1
Issue 2
Issue 3
