If you look at my previous pictures, the p/n are on the pulleys and it looks as these are the same as my 2016.
You sir are correct. My Axys looks identical to this except with the '14 pulleys.
Yes, I'm currently running my '14 pulleys on my Axys. So far so good.
This looks promising. The reason I asked about the center to center distance was to figure out if I could run the 21/44 pro ride pullies with my stock Axys QD belt. I hear what you are saying as to whether or not the tighter clearance on the 3.2 will contradict the added traction. I intend to find out. We have a 2013 pro in our group with an X3 162" and it trenches noticeably less than a 162 Axys 3" or 2.6". With the stiffer duromiter of the new tracks they may need to soften up a but with some miles or perhaps they are a touch too stiff. I am hoping camoplasts lug design on the 3.2 will add more performance than the added profile.
Both pulleys are from my '14 and using the Axys belt and the Fire n Ice belt deflection kit, no tensioner is needed. I also switch out the 2.86 7T drivers to 2.86 8T drivers.
How much riding time do you have on it Rich?
My concerns are that increase of the lower and decrease of the upper will not change the contact area the same on both sprockets.
It is encouraging to see that you have been able to do this though.
On the horn with Paul right now... his AXYS is running the 21 top (ProRide) and 43 (AXYS) bottom gear with the FNI deflection guide... He thought you were running the same setup??
Curious what the actual tension is on the belt in your application...Tension is one of the most important factors for tooth-shear-resistance.
Paul said this photo has the stock top/bottom AXYS cogs... is that correct?
So you've basically geared up your AXYS? Why?
