if yes, what pipes have you found to fit and did you have to cut, fabricate or modify anything for a good fit?
One problem I have is that the PSI exhaust flanges I have are 4 hole and I think the angles were originally designed by PSI for the Gen II chasis. I believe the Polaris VES motors use 3 hole exhaust flanges and the angles may be different??? It looks to me like the SLP, PSI, and CPI twin pipes all have the 3 hole exhaust flanges.
A second problem is that the PSI cylinders are a bit bigger and wider than the stock Polaris VES cylinders and so the PTO exhaust flange is closer to the PTO shock tower bracket and it looks like there in now not enough clearance for the PTO side pipe.
You guys have any advice????
thanks
thanks
