R
Rush44
After several days of tuning I can say the Dobeck Performance Gen4 fuel controller is the way to go... hands down. I was able to get the controller calibrated for my riding and today I didn't have a single pop, hesitation, or overfueled idle engine death. The controller responds insanely well to throttle chopping and holds whatever AFR I desire ALL THE TIME. Let me go over the Gen4 advantages to other controllers on the market:
The modes on the Dobeck controller are Green, Yellow, and Red. Green is your idle and near zero load mode. You will be in this mode when warming up the motor, letting off the throttle between big pushes, and when descending under little power. The Yellow mode is mid-range but you won't hardly ever use it. Red mode is your power mode and you will be in this mode when doing anything that puts the motor under load. 98% of your riding will be done in Green/Red but you can adjust how you enter these modes directly on the controller.
Using the MODE button on the controller you can simply add/subtract AFR in the Yellow/Red modes and when you are in those modes the Gen4 controller simply modifies what the stock ECU sends to the injector in order to achieve the desired AFR. The desired AFR is reached in less than a second upon entering Yellow/Red mode. Green is a simple trim adjustment from stock and based on the ambient temperature of the day you make a quick adjustment once the bike is warm to remove or add fuel. Another feature of the controller is the ability to control the Accelerator Pump so that you can tell the controller to add or remove fuel when switching between modes. I added some fuel for a quick fat burst when I smack the throttle so I don't have a chance to lean the motor out when it's under the most stress.
All in all, the controller far exceeded my expectations. I believe it is THE controller to have now that I have reviewed Bazzaz and Dobeck. There are just so many more options with the Gen4.
http://dobeckperformance.com/GEN4/Gen4technology.asp
- Stock wiring harness : No need to replace your entire wiring harness and stock ECU. Because of this installation takes 10 minutes and can be reverted to stock by simply unplugging the gauge.
- Constant AFR no matter what the conditions : Because the system is live you can make minor adjustments to the unit on colder/warmer days in just a few seconds. It does not take a specialist to make these adjustments.
- Cost : $300. It's half the cost of the closest competitor with many advantages.
- Tuning based on engine load, not throttle position
- Multi-mode adjustments (more to explain below)
