Like the title says will stock reeds hold up to boost? Ill be running low boost likely 6-8psi but I know from my cat that 8psi was plenty to destroy stock reeds, is the pro the same?
The stock Pro reeds do to well. There is always factors that can directly affect them like intake temps but the stocks work very well.
I will never run Boyesen Reeds again as the tips break very quickly.
The best I have seen are the new Vforce 3r reeds which are factory for the Axys chassis 800's. The pedal is not too long, they have pieces to keep them from opening to far and the are Carbon Fiber for strength.
Vforce 3's all the way.
Well, mine came with Vforce 3's from Carl's so maybe they changed their minds haha. I don't know. Mine didn't have any issues from the previous owner so I'm guessing they are good. Running water to air intercooler. Not sure if that makes a differenceCarl's highly advised against the use of v force on boosted sleds, said they weren't staying together.... Until now. Now the new axys comes with v force so not sure what changed........I've had great luck with the stock reeds running 12 psi. Air to air Intercooler.
Maybe I'll pull mine off this weekend and take a look at them. I have to do some work on the sled anyway, so maybe a little research is in order.
I'll be sure to take some pictures of the petals and the tips if I get around to pulling them out this weekend.I don't know for sure why they changed their mind so fast. I wanted to get a some reeds to replace mine when I did the top end and found out that you have to buy the entire reed cage assembly from Polaris and that Polaris doesn't make replacement reed petals. Which made me want to get v force so I could just buy their replacement petals when I needed. Upon taking to Chris at Carl's he said not to do the v force and that they had hell with them on boost. But I know carls built sleds last year using v force and now they are on all the new H.O's. Mines not idling like it should so I think the reeds might be giving up..... Prolly buy a set of boysen super stock reeds to replace the reeds on the cages I'm pulling out just to have a spare set on hand. I already purchased the whole new Polaris reed assembly's to install when I do the top end.
Turbo performance sells turbo reeds for around $50-60 set. I have them and no issues. Great customer service.
I'm curious about trying the new vforce3r's that are in the axys, would like to try them but at 380 cdn I'm not gonna Guinea pig them
I gave in, will be testing vforce 3r's on my t-pro, I like how the petal is supported when fully open
