digitron install on mach z 1000sdi
C
cs1006
anyone know where to drill on the crank shop twins 1000sdi for probe mounting distance from piston skirt out, wiring also raceoaks used have no instructions at all thanks in advance
If the pipe manufacturer doesn't have a known recommended experience then we advise 7" to no more then 9" from the skirt on twins. Matching the distance and tip depth 9I want them bulls eye) for both probes is far more relevant then actual down the pipe position (within reason)
go to www.digatronusa.com and download the user instructions from their website. Please know that they were written by a person with more indepth knowledge of the application which has shown to be less then helpful to the inexperienced masses. Then go to my website at www.f-bombracing.com and see the digatron tech page. Follow that information to the T and get the most functional field use from that instrument.
Oh and ps..avoid radical pipe bends when placing probes. If you are in an area that one or either might have a sharp angle bend for your application move closer to the engine...
