Difference Between 13 and 14 Rails
rernst220
New member
Is there a difference between the 2013 and 2014 Rails? They have different part #'s, looking for one for my 14 and found a cheap 13 rail.
Thanks
They should be the same profile rail. The 14s had either natural or coloured rails. Just the Assault rail has different profile than a pro.
Speaking of rail differences. Are they all the same? My '13 155 has upturned rear. I read they were straight but mine are not lol.
Did I overuse the stock suspension in my first year? They sure look equal and true side by side.
only the 144 has tip up rear rails! sounds like you need to do some work and maybe a shock re-valve if it bottoming out hard. Worth asking if you still are have a warrenty ?
Hmm. When I had my suspension on the steel table last fall ('13) I noticed tipped up rear (about 1/2"). Since I was changing suspension I disassembled and removed sliders and could not see any tweaks and both rails were identical.
So I took my piece of string and checked a '13 on the floor at the dealer. Same thing. Weird eh.
