Ain't that the truth thoughThings that hold 30,000+ PSIG fuel pressure arent cheap.
Isn't that all about condensation in the oil pan?one thing that has not been mentioned (I think), frequent short trips that don't allow the engine to properly warm up can be a killer for a diesel.
So when is a Diesel FULLY warmed up Andra?If you work a 6.0 gas mtr like a DIESEL it's going to last 85k to 120k they just cant handle the stress .
I know that seems like the simple answer.That would be when it reaches full operating temp Chris.
But I wonder.
We usually look at the water temp as a sign that an engine is "warm".
But I would guess that massive supply of Oil is probably a better location to measure Temp. When the oil is good and HOT, then the engine is really fully warm.
I'm not a mechanic, probably means I don't really know what I'm talking about
Heard of a farmer in my area that used his new diesel truck to drive from his house to the barn one mile away. Blew the engine after six months.
He either got a piece of sh!t or he was doing 0-60 test runs to beyond the redline in second gear from home to the barn every day.
You guys ever see the torture tests the perform on engines? Extreme hot, cold, dust, humidity, run at full load full rpms for days on end.
Come on.Better be "heating" up your transmission and axels with a torch before you drive the truck then . Don't want that cold non lubricating oil to ruin the axels, bearings and transmission
Come on.
We are really taking about two very different issues here.
The Engine oil NEEDS to get good and hot to remove any condensated moisture and to burn off any fuel by products that it accumulates while circulating cold, DOESN'T IT?
