FWIW, when I'm not towing, my 07 LBZ runs best with the winter front, upper only, when the temp hits 30F or lower. If I'm not towing, truck will not reach 180 without the upper front below 30F. At temps below 10F, it also keeps the Allison nice and warm, eliminating cold shift issues (and I'm running pure Transync in the Allison). LLYs and LBZs have a larger radiator than LB7s. If you use a winter front, NEVER run it when towing, it restricts air intake and will starve boost, not to mention start to get hot. Run 5w-40, it will turn over easier. My truck has never failed to start, 160k miles, since new. I only plug it in when temps go to -20F if I can easily, just less wear and faster warmup. It's not a 7.3 Ford. The 0F and engine heater plug in issues are real. I've never gotten a CEL from engine heater, but my friends have. I just seldom have to plug in the truck.
Fuel additives depend if I'm on the open road, or fuel locally and know the fuel quality, and temps. I do have a 50W semi filter heater wrap on my fuel filter - FWIW, the Dmax filter head heater is thermostat controlled, and will shut off at engine temp. First two winters I gelled twice, before I had the filter wrap, at full operating temp, with air temp at -25F, towing. Both times after fueling on the open road, after double dosing additive. Had the head flow tested for restrictions, and tested fine. Did I get some bad fuel, bio-fuel, etc., probably. Said F-it, and just put a real filter heater on it, with a cab switch. I use it less than 10 times per winter, but I know my stock filter will NEVER gel again. Complete filter wrap, wiring, switch cost all of $50. JMPE. Good luck.
