Diamond Drive leak?
1
1080paul
I have a BDx diamond lite drive and I have changed the gears a few times with no leaking problems. I took out a bunch of shims to get my alignment right and now I have a leak. It doesn't leak just sitting there but I a have a light mist of oil everywhere around the DD drive. I wonder if its not venting now that I've turned the allen bolt in another 1/4 inch? .
If you are running the B.D.X. adjuster/Bolt I'm sure it has a cut along the thread to allow venting along the bolt out through the adjuster.....
Is on the Case or Cover or all over the D.D. ?
Maybe the upper bearing and seall are needing a change?
What way does your seal face on the lower output shaft?
The oil is heaviest around the case but the belt has thrown it all over. Not much on the clutch. Not sure on the seal but I have never removed it so it should be correct?
The thing is...It wasn't leaking...I removed the shims... now its leaking??
