I rebuilt an 04' 800 Vertical Edge this summer, bad rod bearing and PTO piston. It has the SLP race twins, and jugs from an 02' so no decompression holes, no porting, stock head. I've put 100 miles on it, no issues first 90.
Had it out on Sunday and when going down the trail the deto sensor would flash at me if between 6200-6600 RPM, but never below or above that. I heard it too, so I'm confident its not just a bad sensor. Never flashed in the deep. Plugs look about right: dark tan/brownish, even, and dry. Checking piston wash tomorrow to be sure.
I unload at 9k and only move up from there, been running 91 non oxygentated fuel. Timing is at 29.5* BTDC with TPS unplugged @ 3250 RPM (I'd like to retard it a little bit).
Could it be lean on the midrange (or maybe just crap gas)? It was on the cooler side that day.
Should I pick up a barrel of race gas?
Or just getting a little hot on the trail?
This makes me want to pick up a head meant for twins...
Any thoughts? Thanks for your input in advance.
