I have had 2 ok rides(low snow, bad numbers for my elevation), and 2 amazing rides(new numbers) now on my 2011 BD kit with the intercooler upgrade.
the sled ran great in the am, i had it up to 8 lbs flawlessly.
In the second half of the day i noticed twice when i jumped the sled it sounded funny like it bogged or something right when/after i landed.
i thought nothing of it, maybe from sucking in hot air under the hood? and i could not get it to do it more than the two times i noticed it.
then i noticed on the trail out that my parking brake light would stay on randomly or flicker?
then i noticed my ebc was acting up, it wasnt showing the amount of boost when in the throttle, and it had the set boost turned way down, like 5-6 pounds from what it should be.
i got into it once and hit det(never have before now), then i was able to make it do the same thing again. the whole time my parking break light was flickering on and off, even when i wasnt on the brake.
my stats screen said i was still hitting 6-7 pounds of boost, but the ebc was only showing like 2 on the set boost screen, and not showing boost in real time like it normally does when on the throttle.
so my questions are...
1. is it possible the tail light wiring could be rubbed through causing the sled to act funny?
2. has my ebc gone screwy, or is it probably caused by the tail light wires?
3. would the ebc symptoms be possibly caused by the line coming off the ebc that just vents to atmosphere be plugged with snow?
nothing has changed on the sled, except i changed from ngk non-irridium plugs on the trail out(before most of the issues occurred), to the ngk irridium plugs. maybe i didnt get one of them tight?
any ideas? i really want to get this sled ripping again, it hasnt had an issue before now and the thing is really pretty user friendly, and this sled on boost is amazing.
Thanks,
Andrew
p.s. sorry for the long winded post, if it is easier to talk on the phone my cell is 406-261-2232. Also, i havent had a chance to call Justin Barnes or BD yet, but i will today when i have some time, im sure they will have some info.
Thanks,
Andrew
