Decompression holes
I got caught up on engine building and decided to play around with this on a spare cylinder. Here's my work:
-I drilled out the hole from the exhaust manifold side to 3/32" purely for access
-Then I drilled 1/4" into the second section (from the ves cavity in towards the cyl wall) to 3/64" which worked for the size of my set screw.
-Installed a very small set screw in the hole
It went well, I can't see how anything could go wrong. I am going to go ahead and mod my current cylinders the same way.
In this pic you can see the path of the hole which I have inserted a small wire through
All the drilling is done in this pic
In this pic you can kinda see the set screw in position to be installed
Nice job Dan.
Just a quick question. Did you have to tap threads for that set screw or did you just force it in?
Tapping the thread probably would have been the more professional direction to take, I just drilled them to an appropriate size and screwed them in. The are very secure, so I am not concerned about my choice.
awesome. I think using a tap would be a big pain in the azz, but I don't have a test cylinder to experiment with. So I figured I would ask. Thanks
Yeah if my memory serves me correctly, I did not see an easy way to get a tap in there. The set screws I used were quite small and had a tapered end to the threads so they went in nicely with a little permanent thread lock. Good luck
