peer , and rbl both had 3 diffrent sizes on the width, they were all double row brgs, peer is what bdx uses, ans is the brg in every arctic cat from what i understand after talking with bdx. bdx sells the diamond drive to cat... so they must know there product..
i am not saing i wouls remove the greese seals and try packing more grease in them, that is just what bdx said, it may help prolong the life, as oil doesnt really get near that brg when its being opperated,
you ask y i replaced mine? the same reason y everybody else changes them,,, it was f***ked..., i could tell cus it had a wierd clunking noise when moving slow and letting off the throttle, it would clunk,
also be aware, there is a reason y bdx uses these cheap china brgs.... you guys can do what you want, you can replace it with a 14 dollar peer or rbl. etc... that has a plastic ball retainer in them..... or you can replace it with a 45 dollar fag, ntn, skf brg that has a steel ball retainer and think its WAYY BETTER... well lets have a thought about it... if the cheap plastic falls apart, you get plastic going through your geer set,... it will get eaten up and prally get away with noo damage other than a oil change and a simple brg replacement.,,,,,,, or you can spend your 45 dollars, get the steel retainer one, and when it blows up, your gunna have steel shrapnell going through your planitery, and gear sets.... you wont be getting away with a simple oil change and 14 dollar brg replace are you... hopefully this gives you all somthing to concider.. i would rather the 14 dollar one and change oil and open case one even two times a year, than to have to buy a 45 dollar brg and then have to spend 2 grand on a new d.d or part your sled out ??? CHEERS
