Dd stuff
B
bradburck
Ive got the back 1/2 of case off an 09 dd. the ring gear and the planetary gear. As well as a good Bdx 55 tooth top gear. Lost the brake side bearing on track shaft and in turn lost bearing on bottom gear. When bearing went bore out the bearing slot in the cover. Could build an entire new dd with a new 65 tooth bottom gear and cover. 150ish for the parts. 250$ for it all shipped to your door.
Brad
Can forward pics from bradburck@gmail.com. Load them tonight.
Pics added... perfect for back-up parts, or an 80$ cover and a bottom gear and you've got an entire back-up drive. 250$ shipped for everything.
case 120$
Ring gear 75$
Planetary 75$
Top 55 tooth gear 50$
P1020004.jpg P1020005.jpg P1020006.jpg P1020010.jpg P1020012.jpg P1020014.jpg
