I've been running a 162" Challenger Extreme track (2.5" lug) for the past few seasons with very positive results on my TM1000. Running 8T drivers and 60/60 gearing in a stock '09 non-reverse case.
I'm going to switch to the BDX lite drive and a 3" track for this season. I have a BDX trackshaft with 7 tooth Avid's on the shelf and I'm wondering if I should switch to the 7T drivers (versus the 8 tooth) and if anyone has gearing changes/experience/recommendations on going from the 2.5" CE to the 3" Camo track. Obviously my gearing would be dependent on which driver setup I go with...just looking to gather some thoughts. Also if there was a noticeable impact on clutching?
Have those of you running the 3" with 8 tooth drivers found you have enough tunnel clearance, or is it worth running the 7 tooth drivers and then adding a little taller gearing? The sled runs strong and I'm confident it will pull the 3" fine, but if you have real world feedback, lets hear it.
Thanks for your time!
