Dakota Performance power regulator
BigAir
Anyone running or know anything about the power regulator that Dakota Performance is selling:
Branix regulator
Is this a necessary upgrade? If so, do the '07-'08s need it or just the '09-'12s because of the different electrical systems?
This would work on all the cats using the in tank pump but probably more important on the 09+ years and the 05-06 ones. Good upgrade if you want to run stock pump though for a turbo application.
07-08 had full dc power system using CCU, 09+ have AC system and to get enough power you have to run a capacitor/rectifier harness for dc power to aftermarket pump, not as reliable.
Hi. I don't have any lucky with Dacota perf. power regulator.
I'm running push turbo and my fuel pressure working badly.
I thought that issues may be in BDX fuel pressure regulator. Checked
o-ring on regulator but don't have any good result.
I removed BDX pressure regulator and did same boondocker fuel pressure
setup.
For example w/o Dacote perf. power regulator.
Idle fuel pressure is 48psi. When i do WOT (5psi) my fuel pressure going down
(about 40psi)
I assumed that the problem of voltage and i installed Dacote Pow.Reg.
Start the engine. My Idle fuel pressure is 38psi (on the same fuel pressure setup) I did WOT - my fuel pressure went down and i got about 20psi.
No more Fuel and my sled stopped. Very bad, thought i.
One more thing. It was sometimes. I started engine and saw on my Fuel Pressure gauge is 38psi. My sled worked about 30 seconds, i did short open throttle and my fuel pressure was increased to 48psi, but when i did wot i still don't received any good result.
I don't know what is happening and i ask any help from you guys.
Sorry for my english. With best regards.
My buddy just put one on his push M8T and it seems to work good. I would call Jeff at Dakota if you have not maybe he can help you do some tests to determine the problem. Very sharp guy!
Thnx a lot. I will try to do it tomorrow.
