D&D 1000/1200 pipes clearance problem??
R
Rms Rydning
I have a M1000/1200 with D&D twin pipes.The fit was more than terrible...
And have very little clearance to the ekshaust valves,only 5mm (1/4 inch).
Do any know if this gona cause problem for this valves?Its barly space when the heatinsulations is put on..
Welcome to the world of Twin pipes on a M sled. I had Jaws twins on mine and I had to heat tape and run insulation around the power valve cables and it still melted the plastic on them. It shouldn't cause any problem with the valves as they are a steel line mine still work after having no plastic on them but what you may want to watch for is the pipes rubbing on the valves themselves check when your engine is running to see if they hit, if they do you will punch a hole into your pipe.
Hope this helps some, but your valves will be fine from the heat.
Aaron
It looks like I have to cut this pipes and reweld it to get bigger clearance..
Its a plastic/teflon tube in the end of the wire where it bends in to the valve.
its impossible to
