Millennium ! http://www.mt-llc.com/ If it is stock (no porting or big bore) they should have one on the shelf that they will ship to you right away. Then they refund a portion of the cost when they receive yours.
Thanks guys! Looking like millennium is the way to go.
So far I've only got the head off, but it looks like a piece of the PTO side piston ring broke off and scored the cylinder. One year warranty on the sled was up in January.![]()
You'd think that with how much these sleds cost out of the crate they'd last more than 2000 miles. I'm starting to remeber why I hate Polaris. Love the Pro chassis, but before Polaris figures out how to lose more weight, they really need to figure out how to build a motor.
dude, polaris figured it out, its called 4 year warranty! sorry about the bad luck. Just out of curiosity, were you adding oil to the gas tank each fill up in addition to the oil from the oil tank?
Adding oil is it good or bad?
Topic in Pro section about this right now.
2013 Snowcheck with 4 year warranty.![]()
You were not running ethnal gas, I wonder if that would also have some effect. Know there is a resistor that has to be plugged in.
I sure hope that the station in Hyrum keeps selling the non ethnal next year.
He also told me that they have 3 Pros in the shop right now, each with 1100 miles and each lost a lower rod bearing. None of them were adding oil to the gas tank.
i thought the oil pump was the only way to oil the bearings in the bottom end? doesn't fuel/oil mix just end up in the cylinders?
More details please! So far, you're the first person I've heard to say anything bad about them.I had a terrible experience with Millennium and would not recommend them to anyone.
There has been some debate in the Pro Ride section about this. Supposedly the angle of the injectors will only lube the top end if you add oil to your fuel. Since I have my sled all torn apart, I think I'm going to turn the oil pump up, AND add a little oil to the fuel.i thought the oil pump was the only way to oil the bearings in the bottom end? doesn't fuel/oil mix just end up in the cylinders?
