Hey whats the best thing to use for cutting out the alumin. for the footwell vents??
I got a set of slp ones and want to get them installed.
Just did mine a couple weeks ago. Drill corners and use jigsaw but BE SURE TO PUT TAPE DOWN. It states this in the directions but after a few Jack and Coke's, I neglected this step and put some scratches on my aluminum. I also recommend throwing a sheet or towel over your entire motor, pipe, clutch, belt, and airbox. It makes a huge mess and although I covered everything very carefully, I still had to dig out pieces of metal. Good luck!!!
I used a dremel tool and it was quick and easy.. any other tool would be to large/bulky to fit in the shock tower with A arms and shocks attachedWhat is the best tool to use on the plastic for shock tower vent cut outs?
I used a jig saw.
Shock tower vent cutting?
I used a utility knife and a blow dryer to heat up the plastic to make it softer/easier to cut thru.
Pete
