On my crossfire 7 I am only getting about 7100 rpm. First thing I did was check the APV, I cleaned them and checked the length which is in the middle of the spec. After this I am now spinning about 7300-7400 rpm. The servo actuating but I am unsure if it is able to hold the valves open because I dont want to maintain those speeds on a stand. Also if I come to a stop then pin the throttle I will spin up to 7800 rpm but then it will fall back to 7100 or so, and if I slowly work my way up to speed it will only go to the 7100 rpm. I looked over my clutches and did not see any broken springs. The secondary spring was backed out so I tightened it with no difference in results. For some reason I have a feeling it has something to do with the valves. I am getting quite frustrated with this problem, so any suggestions or help would be much appreciated.
