cream color oil
Took out a piston and the cylinder due to peice of rave valve breaking off and falling in. Noticed that both cylinders were flooded and the oil in the crank case is creamy and thin. Is this from all the fuel or even antifreeze. Any ideas? Pedimo grease from bearing?
check resivior to see if its cream colored in there also , could have a bad seals on water pump /oil pump shaft
