M matty_d New member Lifetime Membership Feb 22, 2010 #1 I was wondering if anyone knew if a Crankshaft assembly out of a 2005 ZR 900 will fit in my 2003 1M 900. Any help would be appreciated thanks alot.
A Arcticatdan Active member Lifetime Membership Feb 22, 2010 #2 No it won't the 03 is a carb model and they are different from the EFI models
M matty_d New member Lifetime Membership Feb 22, 2010 #3 so The bottom end is different?? I thought it might be the same base just different top end?
Idcatman1 Well-known member Lifetime Membership Feb 22, 2010 #4 The 05 ZR came either way, carb of EFI. If it is a crank from a carb engine it will work. The mag end on the EFI engine is bigger, but the rest of the crank is the same. The mag ends can be swapped to make an EFI crank into a carb and vice-versa.
