I have an interesting running problem that I've been trying to diagnose for 2 weekends.
Whenever the sled is hot and I give it WOT, the sled will bog. When the sled has cooled down, I can hold it WOT for ~10-20 seconds or more before it will start to bog. I am not seeing any lights on the gauge when the sled cuts out. The running issues started ~4 weeks ago with the random instances of loading up on the bottom end. Then the WOT bogging started ~3 weeks ago but only happened after 40-50 seconds of WOT. It has slowly progressed to cutting out almost instantly if I've been riding it hard for 20 seconds or more.
For diagnostics purposes, I held it WOT on the trail after it started to cut out and it has a pretty consistent noise of what sounds like the ECU cutting ignition(holds pretty steady RPM and has a repetitive bog-bog-bog-bog-bog exhaust note).
I thought the EGT sensor was starting to get faulty and causing the ECU to cut ignition. But today, I swapped EGT sensors with a working sled and it makes no difference. I'm starting to lean towards a bad crank seal, injectors, or fuel pump causing a lean condition which is being picked up by the EGT sensor and causing the ECU to cut ignition.
Sled is 2012 800 with about 3000 miles. This is the first problem that I've had with the sled. Engine is stock with an SLP pipe and PCV with the SLP map.
