men i know all the hoop la and crap that is out there about these things. All im looking for is a semi descriptive method to check the runout on the crank. Primary is off and at slp for cleaning balancing and rebuilding. any help is appreciated.
Get yourself a dial indicator, and a solid way to mount it (no, using a mag mount on the SLP torque arm isn't solid enough). Put the indicator as close as you can to the crank seal, pull the plugs out, and turn the motor over. You shouldn't have more than 0.003" runout. If you do, you're a ticking time bomb. Some guys pull the recoil housing off and rotate the motor by the flywheel, I just used the pull rope. The important part is making sure the indicator is mounted solidly to the block, or your readings will be off.
I've always been told to check it right at the seal... so I dunno man! I was always told not to check it too close to the end unless you want to scare yourself real badRMK Cowboy,
No pi$$in match, I was told by SLP to check 'em at 1" in from the end, I've always checked them a little further out than that.
Are you sure about checking 'em that far in????????????????????
Just wonderin' what the correct method is if there is one??
Thanks
Too many zeros Wayniac, 0.000" to 0.0015" would be what you were looking for. This seems tight to me as well, I think you should be concerned at around 0.003" or more IMHO.
Any suggestions for getting it that way? When I checked mine the closest I could come was a mag mount indicator on the SLP torque arm... still not good enough.Needs to be rock solid on the motor.
