T
trestlecreek
I also posted this on BCR. Today I took apart my secondary to put in a delron washer. Between the two clutch halves is a brass washer that allows the belt deflection bolt, and tool to open sheaves up presses against. This washer was bent into the inside clutch bell and cracked the clutch right under where the gold cup is placed. I dont know if it needs replacing. But i'm affraid the crack goes 1/3 around the center area. I tried to find just the inside half of the clutch on the micro fische, but it doesnt show as a seperate part. I also looked on TEAM website, and cant find the clutch half there either. Does anyone know if just this part can be bought seperate? I just purchased the additional 4 year warranty, I know bushings, rollers, pins, weights and belts are not covered, I wonder if the actual clutch is?
