[when you say smooth are you referring to no vibration? Is it four stroke smooth? If that's the case I'd be interested in going back to a 500
QUOTE=M5-;3854145]My Cr500 was basically a stock rebuild last year with a pipe and 38mm PWK carb. For as basic a build as it was I was totally impressed with the bike even stock. This year I am going to freshen the engine up and maybe have Adam do a mild port job on the top end. I will likely also pulse inject the carb. I've ridden SB's bike and the difference between his and mine is how smooth his motor is and how fast it accelerates. It has gobs of power down low. The top speed of the two bikes are very close but his gets there much quicker and like I said before its so smooth after the pulse injection.
If you can afford the bill Adam builds an extremely nice motor with the twirp porting but regardless I'd pulse inject.
M5
