Thanks Reeb. I am mostly after the weight...if I get a couple extra HP...great. Did you have to change jetting?? How does it sound?
go with the cpi pipe i put one on my xp and i like it a lot it is about 10hp and you can feel it it was a big difCPI claims 11hp with their silencer....any one ran one???
......no problem with your results, but what's your elevation? pipes developed 5000 feet higher than you will probably result in different outcomes...cpi pipes are developed at over 5000 ft, and are tested and modified for riding in the 7-11 k elevations, where they work very well....www.dynotechresearch.com/techarticles.asp
anyone who really wants to know the actual power gained or lost by aftermarket things like this needs to follow the technical data on my website. This is a listing of independent dyno test information available to subscribers, who by subscribing ($20/yr) support our Consumer Reports-like testing.
My facility is 1000 ft, and you can see that the Stock, CPI, Aaen and DynoPort single pipes all flow within 1/2% airflow CFM.
How is the CPI pipe "modified" to work well at 7000 ft? we should dynotest that same modification to see if that might help here as well.
