H
hatchers
I am installing my CPC stage 2 kit as we speak. The kit is awesome, clean and not hard to install.
Mavrick, the CPC also has an upgraded fuel pump which replaces the stock fuel pump. It also includes a high volume oil pump. They even include a wiring harness for the new fuel pump. Cutler has been playing with turbos since the 90's. I saw one puch kit on the hillls and they were messing with it all day.
The Cutler kit comes with EVERYTHING you need even clutching. You just need AFR/EGT gauges. Do a little more research, it says right on the cutler web site that there is an upgraded fuel pump, like the push. And the Cutler kit also cools the turbo with water....I just hooked up the hoses yesterday.
And a buddies Boondocker kit had to run about 1.5-2 psi more boost to run neck and neck with the Cutler kit. The CPC cold air intake brings in much denser air than the underhood intakes on the other kits.
Go Cutler and you can't go wrong.
This is the most misinformed post i have read in the last 5 minutes, thank you sir for the good laugh
