CPC 900kit in M8 PG?
i would also be asking another question in addition to yours.. is the extra power worth the loss of reliability and more tuning involved with having a big bore turbo?
D&D 901 big bore plus PG turbo
I have D&D 901- takes the stock 145 HP and bumps it up to 185 HP, then add boonie PG turbo- 210HP all day long- mine is also RG capable- 4 injectors capable of 280HP but i will run it as PG only
as I stated before, I will say again
the stock dual injector turbo system is capable of only about 210 HP, on a pump gas, the difference between a07-09 m8 is about 40 hp with big bore, and only 20 Hp on 2010 and newer m8, the turbo exceeds the big bore, but you will gain a lot more low end torque
