corona virus
My .02…
A newer Piston Bully doesn’t have safety switches on the doors, whereas a Prinoth does. On the Prinoth, when either door opens, the E-Brake engages automatically & the machine will not move until the E-Brake release button is pressed. On the Piston Bully, the E-Brake engages when you turn the switch on & disengages when you turn it off. Both brands will move via gravity without applying power to the tracks, coasting if you will, if the brake is off.
Let’s just say (w/Prinoth) l used to feel comfortable standing on the tracks draining the bladder with a door open. Not so much with the Piston Bully. ?
I think he exited the Piston Bully?(?) for some reason without applying the E-Brake, then it started to roll & the only way to get into the cab is from on the track, which is now moving, it took him under & most likely the bogies. ?
According to CNN, which received the report through a public records request, it states that Renner's PistenBully snow groomer, which weighs at least 14,330 pounds, as reported by Fox Business, started sliding towards the actor's grown nephew, "causing Renner to exit the vehicle without setting the emergency brake."
The report further states, "Although the Pistenbully had some mechanical issues, it is believed based on our mechanical inspection that the parking brake would keep the Pistenbully from moving forward. When Renner attempted to stop or divert the Pistenbully to avoid injury to (his nephew), he was pulled under the vehicle by the track and run over.”
Any chicken owners?
Omega-3 fats have been shown to help prevent heart disease and stroke, may help control lupus, eczema, and rheumatoid arthritis, and may play protective roles in cancer and other conditions. Omega-3 fats are a key family of polyunsaturated fats.
Eggs contain 9 of 9 amino acids the only other that contains all 9 is quinoa. Without the help of all 9 amino acids you cells can not get rid of toxins.
What was normal for health intake a little at a time threw what was an essential diet is being taken apart little by little.
In a nut shell a weakened immune system can not defend itself.
This will open all sorts of doors.
Approved for use in people aged 18 through 64. AFLURIA Quadrivalent also may be given by needle and syringe, for people 6 months old and older.
An adjuvanted flu vaccine for adults 65 and older. Learn more about FLUAD® QUADRIVALENT. Do not give to those with history of severe allergic reactions to any part..
PERFECT
