corona virus
Next time you talk with your doc, and if you are in the mood, see if he can give you clarification on what the test you took will prove. 1) Ok, it tested positive - can that test you took discern between Covid 19 and other coronaviruses that have been around since 1920? 2) Is there a test that can show an isolation of THE Covid 19 infection? 3) How many times was the PCR test amplified to give the results it did? 4) Will it show if you had the delta variant? 5) - Is there a test that is available that can prove it was the delta variant?
supposedly the positive sample from the clinic is sent to the state health dept. Not sure how it is tested once it goes there.
Out of stock , order is back ordered , might have to down load the electronic . Any body read this yet besides listening to his interview ?
This is talking about hart attack increase from 11% to 25% after the vaccination
Let me get this straight , the jab causes inflammation and increases heart attacks 11 to 25%
Not a doctor but I'm not sure how inflammation can only go after just the heart , how about all the organs ?
Say you have weak kidneys ? Would they be a prime candidates for failure ? How about an inflamed prostate ? Might be a run on catheters.
How about those over weight , high blood pressure or have a run of bad luck for heart attacks in the gene pool ?
And they want those with underlying conditions to get jabbed ?
Correct me if I'm wrong but that pretty much sounds like a death sentence .
Don’t forget those with erectile dysfunction. Exacerbate that organ issue and your outtie ends up an Innie and now you’re looking at incorrect info on your drivers license.
Those lines are frickin long.
