Make your ETEC 800 razor-sharp for only 3500: -
The kit sold since 2011 and has now passed the 50 + in number of satisfied customers (2013-09-17) enables us to go out with
advertising to the public. Now anyone can get access to the huge throttle response and performance 800 Etec engine is built to the same time we unlock all the features of speed meter for only 3500: - ink return shipping. Send cdi / injector box and speed gauges to:
M.Performance
Brudtallsvägen 14
792 33 Mora
tel 0250-71321
"mullemora@gmail.com"
You can also get here by snowmobile, often the same day you call!
Kiruna-Mora with Bussgods is 2days!
I make all boxes the same day they are received!
Film, see the performance here.
Opportunities in the injection box, which includes:
Up to 8 keys, some of which can have a maximum 70kmt.
Recent factory update.
automotive info and history of speed and time.
Maybe you bought your beg, and you want your listing to stand in the box.
O maintenance reminder, little more odd requests, which included: O the running timer, for those who want to run into the engine itself, as was done in ancient times. Removing automatic engine shutdown. Removing Its key feature Enable relay output that can start a fan . (As Commander) in 2013 so they changed the connectors inside the box at the Rave valve sensor vs Throttle position sensor, so you can not have 2011.2012 box on a 2013 or vice versa, but I can fix it! Clear the entire box and make the New Again, note the keys have to be reentered. Resetting the oil pump
Opportunities in the velocity gauge, which includes:
Watch, if you have the battery, otherwise it will be a timer, which is reset every time you reboot. 2011 Ski-Doo, water temp gauge. Lap Timer 2012 and Lynx 2013 Lap Timer Different languages (Swedish) in the display Water temp gauge bars on the left side. (Ski-Doo) Water temp in large numbers in the lower display. 2013 & 2014 Leaning meters Lap Timer Different languages (Swedish) in the display Water temp gauge bars on the left side. (Ski-Doo) Water temp in large numbers in the lower display.
