Told yesterday tank has been redesigned and on back order. Dealer said put her away and will get to it in the fall
Throwing this idea out to the masses: Why not run a different coolant? Bear with me, there is a story...
Back in 2004, I was looking for ideas to shave weight off of my (cough, cough) ski-doo rev 159. The cooler was huge, and perhaps overkill for the chassis. I cut the cooler to half it's original size, and started using Evans NPG+ coolant. Sled never ran hot, and I kept that machine for three seasons. It protects down to -40F, and doesn't boil until 375F, and unlike regular coolant, it doesn't expand nearly as much when heated. I've been fortunate enough to not split my tank, but it is insulated, my exhaust is fully wrapped, and I'm using Cat's vented side panels (mine is a BC250 kit). One could hear the coolant boil from the turbo when stopped, and I topped up after every trip, as it would push coolant from the tank overflow periodically. I'm open to suggestions / comments, but my plan for the upcoming season is to switch both sleds over to Evans and run a lower pressure cap to get rid of some pressure, and prevent the boil from the turbocharger. I'm not affiliated with then or selling anything, but it might be worth a look - I know I'm going to try it...
I took my time ensuring the cooling system was bled properly - I suspect I get the occasional push as I tend to overfill the bottle (mainly peace of mind as I can't check the level on the POS design without removing the hood). The level has never dropped below a certain point, and I generally ride 5 days in a row before checking again...For what it is worth. . . . . I have not had any coolant push out on mine. Can't remember what I put back in it when I did the turbo(bc250). I know i did add water wetter to it though. But also turns out mine is not a belt eater either. So i am lucky I guess. Just had an issue with a chain and some broken rollers in the secondary. I feel the chain issue is likely still caused from the movement of jackshaft caused by it being linked to a 150 lb weight that floats around on super soft mounts.
I also took great great care to burp the sled when I finished the project. Likely was overkill but may be why I don't have issues with coolant? Not sure I guess. But I am definately worried about the tank now.
Can I weld the seam with it in the sled? I don't really want to drain the coolant down.
Also lucky mine wasn't a belt burner, but I scrapped the chaincase for a C3 drive as my chain was junk after 500 miles. Like yourself, I worry about the coolant tank cutting my ride short. I haven't welded mine yet, but I suspect it would be damn near impossible to do with it on the sled, other then the outside seam - JustBoostIt would know for sure, as he's fixed a bunch of them...
My only thought about replacing coolant was to eliminate localized boiling, and reduce pressure on a slightly "flawed" system - reducing the system pressure by 8 psi may enhance longevity
