Just purchased ski doo 2004 800 ho the coolant hoses to carbs have been disconnected and plugged. should i reconnect them? and why were they disconnected?
Got a few weird posts on here tonight!
How does alcohol in the gas tank/float/bowls/venturri mist/crankcase, unstick frozen slides or iced up carbs? It doesn't!
You would be better off drinking your alcohol and pizzing on the carbs to get the sled running again.
Ice forms in carbs because when the work they create low pressure and evaporation that lowers the carbs temperature. Any moisture in the air will turn to ice and stick on the carbs and then the carbs can't do their job anymore. The usual temperature for the formation of carb ice is +10c down to -2c, however on sleds the snow and steam lowers this temperture to almost anytime you are in loose snow and making steam.
However, if you are flying an aircraft with a normal air cooled engine and the engine starts to slow down due to ice build up in the carb, and you forgot about the carb heat until everything was quiet, you should still drink the alcohol. You will not be able to pizz on the carburetor, but it will make your stupid azz crash landing that you are going to have a little more funny anyway.
Oh man I thought you were goneGot a few weird posts on here tonight!
Cant really say on your sled...maybe if the previous owner was rejetting , say to ride at higher elevations. The coolant lines are a pain. Yeah I know DPM is supposed to compensate for elevation changes and they doo a good job of it but are still limited by jet size. I ride mostly between 2500-6000 feet but when I go to Mc Call or Jackson I drop a jet size or two. Yes the heated carbs will keep you from having sticking carb slides. I just find the sled wont run as good with them turned on, cant explain why... I just notice a difference. Hope this helps, DinoThanks for the info i will hook them back up. I appreciate the help. Why would they be unhooked in the first place?
