I have been trying to figure out how to update a 2011 to 2016.
Been concentrating on getting rid of the Double Limiter straps and put some flex in front arm.
Here's the main challenges I've found thus far:
- Front Arm is 2" longer on 2016
- The 2016 Suspension has no limiter strap.
- Front Shock mounts differently to top of front arm of the 2016.
- The 2016 shock is on center line on upper shaft were the older kits have off axis tabs to mount top of shock.
IMO it is an uphill battle to stuff the 2016 front and rear control arms under the older kits. I think it possible if you have good Fab skills and access to a machine shop. For me the 2011 is a labor of luv. $$$ and time wise I would be ahead to replace it with 2016 or newer kit.
Our 2011 kit we have done the following updates.
-Rotated front Spindle (Fabricated a new fork clamp bracket)
-Hardened gears
-2013 Bearing Update
-2014 T/S Ski
-2015 Double Bearing Update
-Have a 2013 120 Track but the drivers didn't come in time.
New Adjustments: tight on the track tension to try to keep the drive lugs from hitting the and wearing the 2 limiter straps.
Test riding the 2011 kit Saturday gave me the Impression to skip the flex arm. After we put the 120 2013 track on we may stop the updates there. The kit works just how it is.
Hopefully tonight I will be getting my 2016 LT out and pop-ing its cherry.
I Will follow your thread I am Intrigued with the 3rd Shock. I plan to run the 2016 LT with the Flex arm Locked out or mostly Locked Out.
My TSS is still in the Box. Will get 3rd shock sorted out Early January and find out what its all about.
