Constant throttle blipping while riding?
it’s all about your clutches. Yes it’s better for the motor to not be a steady throttle but the biggest thing is the sharp increase in throttle causes a sharp increase in load on the track which cause the clutches to backshift. Essentially keeping you in a lower gear, allowing you to ride slower with more available torque.
It’s a light switch not a throttle. You flip it on and off, on and off to annoy everyone in the room and the neighbors across the street. You should also blipp the throttle in your pickup every 5 seconds to clean out the tail pipe. Nobody wants a plugged up tail pipe on the long drive out and back.
Tired of hearing about this myth so I'll say my $0.02.
Blipping doesn't cause moguls or a whooped out trail, it's the compounding effect of all the skids hitting the same dips and hucking a little bit of snow at the same high spot behind the sled. I've watched with my own eyes whoops grow on a pow day by just our little group going by..6 sleds, nobody blipping throttle.
Also if you notice when you blip the throttle the track doesn't spin or roost. The sled barely even speeds up.
If you think blipping the throttle causes moguls then everybody would have to be in on it. Everyone going down the trail would have to gun it at the exact same spot to dig a hole in the same spot
times however many moguls there are on a trail (thousands?). I like a good conspiracy but sorry that ain't it. Most riders that I see on the trail are pinning it, not blipping it.
It is not a myth. Been riding for more then 50 years. Blipping the throttle does start the creation of moguls especially on good groom trails. Once a spot is started it will grow with each rider passing over it. If you are blipping the throttle to help with cooling you have wrong jetting or fuel map and would actually save fuel by getting fuel map right ! The wear on clutches from blipping is unbelievably. The blippers just don't want to admit they are one of the biggest causes of rough trails and they will use any reason to make it seem like they are not hurting the trails !!!!
What's a trail?
Throttle blippers (I am one of them, for many reasons) and as mentioned previously; track speed control, setting the track (especially in a side hill), engine cooling, distributing wear on clutch weights proportionately, clutch engagement and flat out “SMASHING THE FUN FLIPPER” for some much needed HORSEPOWER! All benefits while riding a 2 stroke sled, if not all mechanical benefit, definitely brings out the kid in us all that love the feel-good-raw-torque our sleds create! Does it create big moguls….sure, but so does slowing down over top of them and accelerating. Listen, we all contribute to them in some way or another. It’s a just another day at the office so to speak.
Some don’t realize the importance of blipping, some have yet to be exposed to the engineering behind it all and some just need to have a release and feel the power intermittently.
TRACK SPEED/CONTROL
If your sidehilling and you are holding a constant or increasing throttle, you have invited a very good possibility of losing your edge on the hill no matter how you use body mechanics!! Did you ever experience science class as a kid and spin a bicycle wheel assembly and hold the axel with one finger while it stays in the upright position effortlessly due to the centrifugal forces it created?? If not, try it. same principles apply to sledding! You have a giant piece of rubber spinning at wicked speeds and all this assembly wants to do is stay vertical, and at high RPM will do nothing but upright your sled and send you back down the hill where u came from, especially if your not prepared to influence it with some body english and track speed control. U need to blip…..and brake to maintain and slow that track speed down to keep your sled on edge, or just to keep it all in control. Timing is everything with throttle control and body english in this sport.
ENGINE COOLING
To keep that two stroke engine cool while going up the trail requires large amounts of cold fuel being dumped into each cylinder (snapping WOT aka “Blipping”). However, it’s a balance of not kicking up rocks into the sled behind you if conditions are not favourable and keeping your sled propelling forward all while trying to cool it when there’s limited snow and or ambient temps are warmer.
DISTRIBUTING WEAR ON THE CLUTCH WEIGHTS
On the ramp/roller contact surface of the clutch weights, it is known that the weight will eventually form an indentation on them because of constant throttle position being maintained. Eventually leading to a sticky spot in your launch. Blipping keeps this more gradual over time.
This above, of course, are not all the reasons, but some very good ones for understanding “what’s with all the blipping”. Happy blipping!…….or not.🙃
Blipping once your up on the mountain that all makes sense but im talkin about the guys that do it on the main groomed trail into the zones. There is no need for it , sleds are injected. Maybe blipping is the wrong description for what i see, its more like smash the throttle on and off which breaks the track loose. This picks my ass, as i am 1 of the volunteer snow groomers. For a couple of yrs myself and about a dozen or so guys had a secret zone and it never got whooped up, we could do the same speed at the end of the season as we could at the start.
Was out today... a bit later in the day, it occurred to me to try the blipping thing when we were in the trees, and it actually worked surprisingly well. The sled went better, had better tracking and was easier to control compared to just trying to hold it at a steady throttle.
Use to have to blip the dog szhat outta the twin and triple piped carbed sleds specially in mid range could watch the egts climbing and the blip would definitely cool em down , fuelie sleds prolly not so much but probably a little extra fuel at times , habit I guess , and if you have a groomer operator who knows what that thing on the front of the cat is used for, then you would have trails like this all the time to get to the good stuff , most don't know how to properly cut bumps on a trail 😎😎
