Compression
Old & slow
729
394
Alberta
Your engine compression psi should be around 120-140. There are a lot of variables suck as elevation, atmospheric pressure, gauge accuracy, test method etc. This is why you see so many different numbers. To me its more important that the cylinders are the same side to side or with in a few psi. If you are trying to determine engine health a leak down test may be a better choice. If this is a new engine it needs to be broken in for accurate results. Those Suzuki 800 usually take around 500 miles to truly loosen up from new, a rebuild may be a bit quicker.
L
Dec 5, 2022
8
france
I know but the problem is there, I just wanted to know how much compression is on a new 800 engine, on the manual it is written 6.62:1 compression ratio, but it does not specify the compression in psi, moreover the ratio/PSI conversion calculator finds me 97 psi for a new engine, I thought it was low for new...
boondocker97
4,095
2,833
Billings MT
My big bore compression tested ok, but the rings were starting to flake when I took it apart. Leak down might have shown that better.
Anylizer
581
131
Top 'O the Great Basin... almost
Additionally, make sure you are holding the throttle WIDE OPEN when testing compression. It makes a big difference!!!
