J
JTAB
I have a couple of questions for you guy's. If you have an Apex with stock compression and running at 16 lbs boost and an Apex with a head shim or low comp pistons and running 16 lbs boost. What is the horsepower difference between the two sleds and is the motor with the stock higher compression ratio stressed more than the motor with the lower compression ratio? I have always wondered if boost is just boost no matter what the compression is?
I realize that octane is the biggest concern in higher boost applications.
So is this the main reason for lower comprssion?
Thanks Jason
Thanks Jason
