Composite/Alloy Rear Suspension for Arctic Cat
Aren't those chips beautiful?? You guys should have seen the pile of shavings after using the facing mill for the first .400 thousandths! This is the 6061 I picked up the other day. Started as a 4"x3" flat bar stock. So far it's been great to work with! The 1" end mill
made easy work of getting through the material and left a beautiful surface finish. More than likely, these pieces will be powder coated anyways.
I personally would not powder coat any of the heat treated aluminum alloys!
Unless you really know and trust the powder coater; to use short cycle times and very low temp powders Anything over 300 F for any length of time can remove or degrade the heat treatment / temper. If that happens you will lose roughly half of it strength.
I prefer hard teflon anodizing; as their is no weight gain, nearly no build up (0.001"-0.003" build up, and roughly the same amount of penetration) and it is much more durable and last longer than powder coat. Powder coat will start failing / peeling away within a few years. FWIW
We have a powder coating system that I was going to use. But I like the hard Teflon anodizing idea better. I'd have to look around where I could get that done.
It will be interesting to follow your progress and hopefully see the end product. It's sure amazing how those chips expand in volume, kind of like popcorn.
You might phone AMP, After Market Products and see who they use. Every part I've ever bought from them looks awesome but I do not know what type they specify for their stuff. They are in your neck of the woods.
My Google search came up with a few in Portland, but did not come up with much in the Seattle area, surprisingly that maintained a website. Specialty Plating came up as a Yellow page add but did not specify their capabilities of course.
With all the industry marine and aircraft right there on the coast there has to be quite a few I would think. I know there is one place in Spokane as well.
